Beolab 9 using bluesound node (n130)
This post has 12 Replies | 1 Follower
Kgomotso Mabokela
Posts 44
Kgomotso Mabokela Posted: Mon, Nov 29 2021 8:58 AM
Greetings all,
Is anyone else using the Bluesound Node as a preamp for their beolab speakers? In my case I have the Bluesound node as my source/preamp paired with beolab 9 running power link to rca cables. I find that the node struggle to drive the beolab 9's and yet i feel their are under powered, is there any other recommendations one could look at?
Mr 10Percent
So West, Its Now East
Posts 591
deleted response
Mr 10Percent
Posts 591
Good Day,
Im not an expert but I think you should look at the Blue Node RCA settings
1. The Beolab 9's are self Amplified (600w each) and will easily take any, any line level input and they are not underpowered - nor is the Node doing any (power) driving.
2. The Beolab 9's will take a line-level input through either Powerlink or RCA inputs. +/-2v only.
3. I would look at the fixed/variable output of the Node and ensure you are sending the line-out via the Analogue RCA (Beolab 9s I think cant accept a digital input - unlike the BL20s of BL5)
10
Kgomotso Mabokela
Posts 44
Greetings,
I have checked, I feel like i had more oomph using my pc with the lab 9's vs node. The spl levels are definitely lower vs the pc.
The lab 5's are definitely something else are you using the lab 5's with the node? That's the one speaker I'm looking forward to upgrading to.
Regards,
KM
Kgomotso Mabokela
Posts 44
Does the digital input make any difference? Have no experience in that regard.
Mr 10Percent
Posts 591
Have you connected the Bluesound analogue RCA to the line in on the Beolab 9?
Have you ensured the L/R/Line in each speaker is set to Line?
Have you tried Wall/corner/free settings in the input area of the loudspeaker?
Im guessing you are injecting sound via RCA with the powerlink L/R setting on, and its bleeding into the amp. Ensure you are in line mode.
Kgomotso Mabokela
Posts 44
I have made the above selections accordingly. if do l/r there's no signal coming out using the bluesound. Based on my positioning, i have set my speakers to wall, this position sounds very good for me musical consumption.
Regards,
KM
Mr 10Percent
Posts 591
Kgomotso Mabokela:
Regards,
KM
The L/R switches control which active speaker plays which channel. The B&O proprietary DIN cable/plugs carry both left and right signals at line level. If you are inputting at Line/RCA from a non-B&O system, you need special cables. You need to ensure these are good and correct.
Kgomotso Mabokela
Posts 44
The cables I use work perfectly fine. set both speakers to line and when in idle/no signal the speakers go on standby mode and lights turn red. I don't have issues on that front, my biggest query is that the node cannot match the beolab 9's properly. By the times you feel the power from the speakers, the volume is maxed out on the node.
Hope my above statements make sense.
Mr 10Percent
Posts 591
Yes your comments make sense. I believe Powerlink works on +/-2v or +/-1.75V
Your 0-100% on the Bluesound RCA output needs to match this for full attenuation of the Beolabs.
If the voltage specs match:-
1. Problem with the Beolabs
2. Problem with the Cable
3. Problem with the Bluesound.
As a potentially expensive way of fixing this, a Beosound Core or essence will natively take signals from the Bluesound Node and put you in the B&O ecosystem.
A perhaps less expensive way is to test if the BSN is problematic by testing a Toslink/Coax to RCA connection to the Cables?
Other than that, I cant think of anything else that will help?
Kgomotso Mabokela
Posts 44
very well noted.  Will explore the options and thanks for the recommendations.
Kgomotso Mabokela
Posts 44
A quick update:
I borrowed a marantz SR 5006 amp and connected my speakers to the pre-out section of the amp and the results were just as I suspected! The preamp section of the Marantz has better handling/control over my speakers, the sound is more fuller and very detailed.
In  some instances i could not believe I was listening to the same speaker set.
in conclusion the node does not drive my speakers optimally and by the time i reach max volume on the node, only now the speakers are starting to open up. I tempted to  get newer marantz amp with phono, preamp and streaming services inbuilt ie Tidal/Qobuz.
Regards,
KM
Kgomotso Mabokela
Posts 44
A quick update:
Regards,
KM
Page 1 of 1 (13 items) | RSS
