Beonet wiring
This post has 3 Replies | 2 Followers
mjmedlo
Posts 922
mjmedlo Posted: Mon, Dec 30 2013 2:53 AM
Mates
Have purchase and am remodeling a new home.
I have run cat7 to a variety of locations and terminated with the band and Olufsen recommended AMP terminations.
Question is: I have run out of the AMP terminations and am considering using another brand. The problem is all I can find are cat6 terminations. Is there any difference in the terminations?
I'm using cat7 cable everywhere. To be clear I am making all female terminations.
sgresswell
Posts 1
Hi
the AMP (cat7) terminations are shielded whereas the cat6 is not
StUrrock
Posts 995
StUrrock replied on Mon, Dec 30 2013 6:47 PM
sgresswell:
Hi
What's this then ? :)
http://www.dttuk.co.uk/product.htm?product=excel-cat6a-keyston-jack-100-180
As I understand it the spec is cat7 cable with cat6a connectors
I believe cat7 connectors are gg45 not rj45
mjmedlo
Posts 922
mjmedlo replied on Wed, Jan 1 2014 1:59 AM
The BeoCare hotline says cat6 will work as long as it is for shielded connections. The brand doesn't matter.
The other issue is the connectors should be metal and connect with the braided cable. That makes the ground and 'is vital'.
Just FYI
Page 1 of 1 (4 items) | RSS
