Dear Beoworld Members,
Most of the DNS servers around the world have been updated now and most members should now have access to the new forum here.
The following points should be noted:-
Regards Keith....
Thanks Keith for all the hard work .... and also all the Beta testers that helped smooth the way for the rest of us
BeoNut since '75
I am sure the new forum will be loved very soon. One thing I would likt to have changed is the font size of the Thread header lines. Can this be a little bigger or outlined. It is not so easy anymore to have a quick overview.
BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Profile test :)
It seems my fault, but how can I log out? Can't found this option, and currently I have no gold, no founder status
Found log out/log in, but post count is still wrong
