Hello
Had a search but can't seem to find anything on this so far so trying a post. Has anyone out there got a Sonos system setup in their house and how would you say the sound quality compares to B&O speakers?
I'm less interested in the pros an cons of the integration / streaming etc as there seems to be plenty of discussion on this and I personally I think it just gets a bit academic and depends a lot on personal preferences in how you are going to use it. What I'm interested in is how it sounds.
Reason is we're buying a second home (well more a wreck that we have to rebuild) and trying to decide whether I stay faithful to what I'm used to and wire up a B&O setup or opt for an easier to setup and more flexible to change in future wireless approach.
Thanks, Chris.
