MY VX8000 HAS RECENTLY DEVELOPED THE PROBLEM THAT THE TAPE WILL NOT GO FULLY INSIDE AND GETS STUCK SOMEWHERE IN THE MIDDLE. SOMETIMES IT IS DOES THE OPPOSITE WHEN A TAPE WILL NOT COME OUT AND STILL GETS STUCK IN THE MIDDLE. I OPENED THE UNIT IN ORDER TO REMOVE THE TAPE AND TRIED TO LUBRICATE THE TEETH WHEELS. THIS HOWEVER HELPS FOR A VERY LITTLE TIME AND THEN THE PROBLEMS REAPPEARS. WHAT DO YOU THINK THE ISSUES IS AND WHAT CAN I DO? I HAD BOUGHT THIS SECOND HAND BUT NEVER HAD A PROBLEM BEFORE AND THE UNIT LOOKS NEW.
THANKS IN ADVANCE FOR YOUR TIME
Any idea? Anyone?
