Beocenter 9300 doors
This post has 4 Replies | 0 Followers
Orava
Finland
Posts 991
Orava Posted: Thu, Feb 21 2013 5:18 PM
I have a problem with both doors, motors run only second or most two, not enough to open/close doors. Why? Doors are cleaned lubricated and they move just as good as any other door. And motor don't run any longer when belt is off... Anyone?
And what is this?
Orava
Finland
Posts 991
Orava replied on Sat, Feb 23 2013 9:59 AM
Yes, there is clear difference between 9300 and my 9000. In 9000 motors run at least 2 or 3 times longer time.
Is it in 9300 some extra stuff in door motor circuit? That board in middle? As 9300 is based on Overture witch dont have this long traveling doors.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Orava:
The board in the middle is the limit optoswitch.It is aligned with a segmented wheel which spins as the doors operate.
I have had problems with this board in the past (cant remember the symptoms) and I replaced it with a spare from B&O. I dont know if they are still available as I bought mine 2-3 years ago.
Regards Graham
Orava
Finland
Posts 991
Orava replied on Sat, Feb 23 2013 3:31 PM
Oh my, I don't have any kind of segmented wheels there, just same tings that my 9000 has... Maybe I miss something there??
And yes, it could have something to do with that little board, it doesn't seem to have any effect at all, I can even take it out, no difference.
It looks like having optos, but painted to black?
Orava
Finland
Posts 991
Orava replied on Tue, Feb 26 2013 6:17 PM
Maybe, if there is really something missing, I just make some mono-shot to make motor running time longer.
Page 1 of 1 (5 items) | RSS
