Core is connected to lg tv via optical and in turn speakers connected to core and controlled with beoremote 1 all working great. There is an older beosound 3000 which is connected via masterlink to lab 3500 in kitchen. I tried to connect the optical out from the core to optical to analogue convertor then into aux of of beosound 3000, sound comes through to the lab 3500, but even at full volume i can hardly hear it, i can't see any settings in the bang and olufsen app, is there a step I'm missing, or will this not work?
Maybe this thread can help you:
https://archivedforum2.beoworld.org/forums/t/28411.aspx
Hi millemissen
Thanks for reply will try that and let you know if that works
