Can anybody please tell me when i press list on the beo 4 and then select "av" to allow the sound from the bv 3 to come from the beolab 6000 the bv 3 screen goes blank and then have to press the source i.e.. sat or vcr to get the picture back
Also when i press sat on the beo4 it dosent show on the bv3 screen??
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Works as it should ....
AV blanks the screen.
How are your speakers connected? To the Beovision?Option settings?
Download the manuals and you will find out...
Ralf
they are set up thru a bs3 , and were set up by b&o and worked before but has just started doing this for some strange reason also when pushing dtv button on beo4 it dose not registeron bv3 screen regards
BS3 ?= Beosystem 3??
Sorry, you got me confused...
If set-up by your B&O dealer AND not working correctly I'd ask them to fix it.
thru a beosound 3000 and as for the dealer they are no longer ....... but thanks for getting back.
OK, maybe the option setting is not correct!
Attach the speakers to the TV first.
Then change the option settings:TV to 2BS3000 to 0
Press LIST and STANDBY buttons at the same time. ADD? should be displayed. Scroll to OPTIONS (using LIST Key?), GO, (scroll to V.OPT), 2, and from A.OPT, 0.
Taken from a post from Vienna:A.OPT for audio components like BSd 4, Ouverture,...
V.OPT for video components like BVi 7 / 8 / ...
L.OPT for link products like BLb 3500, BeoLink Aktive, ...
Main-system:1 and 2
Link rooms:5 and 6 functions correspond to 1 and 2 but are for secondary "slave" components in additional "Link" rooms4 functions correspond to 2 but need "LINK"
0 = IR disabled - unit can only be operated manually or receive commands via ML
1 = accepts NO commands for "the other side" of main AV system V.OPT 1 only commands for video sources like TV, V.MEM, .. A.OPT 1 only commands for audio sources like CD, RADIO, ...
2 = accepts all commands for audio and video (eg TV receives all commands and sends the audio commands to the audio system in A.OPT 0
3 = not used in the ML system
4 = accepts all commands for audio and video (functions corresponds to 2) BUT you'll either have to press "LINK" before the command or have to select a"L.xxx" command from the "LIST" - used to adress eg an additional BLb 3500 in your living room where the main system is also installed.
5 = accepts NO commands for "the other side" (local components and main AV system) V.OPT 5 only commands for video sources like TV, V.MEM, .. A.OPT 5 only commands for audio sources like CD, RADIO, ...
6 = accepts all commands for audio and video ((local components and main AV system) local components have priority - if you have a BSd 9000 in your main room (A.OPT 0/1/2) and a BSd 4 (A.OPT 6) in your secondary room - pressing CD will start the local CD of the BSd 4 - pressing LIST > LINK >CD will get you the sound from your 9000
ok.....will try many thanx
