Beo5 programming
This post has 4 Replies | 2 Followers
Gerard2209
Posts 9
Gerard2209 Posted: Sun, Feb 17 2013 12:01 PM
Who can help me how to program Beo5 for following option:
Beovision as display for PC simultaneous with A-Aux as soundoutput for PC.
0:000:TV:PC and 0:000:Radio:Aux-A seperate work fine but in combination only sound and no dispaly.
Thanks in advance
Gerard2209
Posts 9
Gerard2209:
Thanks in advance
This is the same as AV function from Beo4
hfat
Vienna, Austria
Posts 663
hfat replied on Sun, Feb 17 2013 3:04 PM
What command combination do you use on beo4?
if you use PC + AV-A.AUX then you should code:
0:000:TV:PC and 0:000:TV:A.AUX
hfat
Gerard2209
Posts 9
I used tv:pc and radio:a-aux
Using tv:a-auxsolved my problem.
Rask
Posts 4
Rask replied on Sat, Mar 9 2013 4:47 PM
Thats probably needs to be done as an macro In the config tool
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
