I have a Beovision AVANT 32 DVD in black and I would like to make retouch paint at the bottom of the frame further to a shock.
On the AVANT the painting process it’s very sophisticated the painting is black is spangled metallic (Similar to car industry) and I do not know the reference of paint.
How to make a retouch on this frame without it sees it in the end.
Your advice experience or feedback is welcome. Cordially, Alain
Cordially,
Alain
I think you have actually found the answer yourself - I would ask a specialist in scratches on car bodies to fix it. It is sprayed in much the same way as a car. Unfortunately, the car body probably most like the Avant is probably a Trabant!
Peter
It's BMW Diamond Black (I think they call it Diamantschwartz from memory)
Lee
