BEOSOUND1
sinbad2222
Posts 3
sinbad2222 Posted: Sat, Mar 16 2013 8:05 PM
Just fitted a new laser head to my Beosound 1.
Unfortunately I am stuck on a problem with reassembly.
There are three ribbon connectors going to the display module and I have pulled them away from the connectors inside the display module when I disassembled the Beosound 1. I need to access the inside of the module to try and reconnect them but I cannot see how to remove the black plastic cover over the display module. - any advice please ?
Peter
Earsdon
Posts 11,991
I think this is what you need.
Peter
sinbad2222
Posts 3
Thanks for your response Peter.
I've now got the ribbon connectors in place and my Beosound is working perfectly.  Phew !   I was sweating a bit !  The trick seems to be to carefully lever the cover of the display upwards with a screwdriver inserted under the bottom lip of the display cover.
My CD player was starting and stopping which seems to be a common problem and caused by a defective laser head. I got the head refurbished by a great guy in England who provided awesome service.  His name is Mark at  mark@av-repairs.com  He has a website :    http://av-repairs.com/
I'll post a new thread recommending this guy as finding new optical heads can be difficult.
Cost me about $120 and well worth it.
bramble
Posts 397
bramble replied on Fri, Mar 22 2013 3:05 PM
Just seen your headache!!!!!, now i understand why the service center i handed my bs1 where so keen to give it back to me...thankfully now works perfectCrying
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Page 1 of 1 (4 items) | RSS
