Beogram 1102 refurb - how to remove flywheel?
richardbell81
Posts 36
richardbell81 Posted: Tue, Feb 12 2013 5:05 PM
Hi everyone,
I know this might seem like a very basic question but how do you remove the flywheel on a Beogram 1102? I've removed the platter but can't seem to lift the flywheel off and wondered if there are any fixings I need to remove first? I'm very new to all this so you'l have to excuse me Embarrassed . I just don't want to break anything before I even get started!
I'm wanting to strip it down then clean and oil the mechanism as it squeaks a bit on start up, and takes a while to get going! I may also need to re-align the pulley on the advice of Søren Mexico
Also, if anyone has any parts going spare for this model then do let me know. I'm after the plastic lid, as the hinges are broken on mine, and also I need to replace the teak veneer along the front as it has come off completely.
Cheers, Rich
Page 1 of 1 (1 items) | RSS
