BEOSOUND 9000
chip197101
Posts 8
chip197101 Posted: Sun, Mar 24 2013 11:23 AM
HI THANKS FOR ALL YOUR I HELP SO FAR, BUT DONE ALL CLEANING AS ADVISED, BUT STILL CD SLEDGE WILL NOT MOVE QUICKLY BETWEEN DISCS, GOES TO MOVE THEN STOPS AND AFTER AROUND 15 SECONDS GOES TO SELECTED DISC, MESSAGE COMES UP CLEANING REQUIRED, AND THEN PLAYS DISC FINE. CAN ANY ONE HELP?? MANY THANKS WAYNE
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Is the glass door fitted? The 9000 behaves in a weird way without the glass!
Have you positioned the 9000 under a strong light or a close fluorescent lamp which can also lead to weird behaviour?
Regards Graham
chip197101
Posts 8
HI THANKS FOR REPLY , DOOR IS FITTED AND CLEAN, EVEN CLEANED ALL BITS INSIDE AS ADVISED, STILL SAME, ANY IDEAS?
Page 1 of 1 (3 items) | RSS
