Has anyone attached a Mac Mini to a Beovision 11 using an HDMI port? How does it sound? I am thinking of getting a Beovision 11-55. Thanks
I'm sure the sound will be good.
Depends on the source though.
I have a Mac Mini connected to my BV10, and I'm happy with the sound from the HDMI.
Too long to list....
bayerische: I'm sure the sound will be good. Depends on the source though. I have a Mac Mini connected to my BV10, and I'm happy with the sound from the HDMI.
Thanks. This will probably be my new music system. Most of the music is lossless and I have Beolab 9s.
linder: bayerische: I'm sure the sound will be good. Depends on the source though. I have a Mac Mini connected to my BV10, and I'm happy with the sound from the HDMI. Thanks. This will probably be my new music system. Most of the music is lossless and I have Beolab 9s.
The music will be sent in it's digital form in through the HDMI, so no different really than a SPDIF cable.
You'll be using your BV11 built in DAC's, and I'm sure they are of good quality.
