Hi all
I wonder if any body can help ?????????????????
I am working on a Beomaster 2400 and I need a tone control or at least the black slider and the 2 metal contact sliders any of the following will work a tone, base or even a balance control ( I know they are different value but the parts are the same )if anybody has one or knows where to find / buy one it would be a great help.I think a 1900 has the same sliders ?? It look like this is a common problem
One is missing ??????????? the other has been damaged
Regards Ron (UK)
Best and I think cheapest is to get a donor unit, if the sliders comes up sale, they go for prices where you can get a unit for the same price.
And yes the BM 1900 has the same sliders.
Hi thanks for the reply I will have a look around
Regards Ron
Where in UK are you?
Swansea South Wales
Have sent you a PM
