which cable required for datalink connection BG8002 and BM8000?
Cplyons
Upstate New York, USA
Posts 6
Cplyons Posted: Sun, Mar 3 2013 6:20 PM
Is a DIN male-to-male seven pin correct? Thanks!
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Mar 3 2013 7:12 PM
Yes, correct. You can get one at Steve's online shop (see banner at bottom). Or if you are handy with a soldering iron you can make one. Only one of the two extra-pins is necessary (7?).
Jacques
tamtapir
Örebro, Sweden
Posts 521
Cplyons:
I think you need a male-to-female seven pin.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Mar 3 2013 7:16 PM
No, no. Male at each side!
Jacques
tamtapir
Örebro, Sweden
Posts 521
chartz:
Ok. If you say so.
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Mar 3 2013 7:18 PM
This is actually a special cable as it is shielded unlike most other 7 pin cables. There is a shield that runs from the casing of the DIN plugs as well as the other cables. They usually have a PH sticker on them.
Peter
tamtapir
Örebro, Sweden
Posts 521
Peter:
Aha, ok! That's what is special about the cable? A little ûberviolence to use it for Beocord then.
I´m learning as fast as I can.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Mar 3 2013 7:31 PM
Yes, mine has the PH sticker, Beocord has a TP sticker!
I think you can trust Steve. It will not be an original B&O but it will work perfectly.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Mar 3 2013 7:34 PM
tamtapir:
Peter:
Nope, not for the Beocord Sir!
Jacques
Page 1 of 1 (9 items) | RSS
