Light sensor BV10
koning
holland
Posts 4,220
koning Posted: Sat, Mar 16 2013 5:06 PM
Is it possible to make changes in the service menu to change the sensitive of the light sensor.
I find the picture/color in the evening a little too dark.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
It is possible that your light sensor is faulty or switched off which can be checked in the service menu.
There is an "Auto Picture Control" which can be switched on or off and it will also display the ambient light values.
The light sensor can be checked, by covering the light sensor so that the TV thinks it is dark, the light read out should go to zero. If there is no reaction, the light sensor may be defective.
Regards Keith....
koning
holland
Posts 4,220
koning replied on Sat, Mar 16 2013 5:57 PM
I checked the light sensor and it's not faulty.
is it possible that i can change the light values so that the picture is less dark.
Keith Saunders
Posts 5,495
The only related item you can change in the Service Menu related to the picture is "Picture Offset"
The default value for Brightness, Colour and Contract is 63 but all three can be changed.
Regards Keith....
Page 1 of 1 (4 items) | RSS
