Ouverture query
Maurice
Posts 108
Maurice Posted: Thu, Mar 14 2013 8:43 PM
Hi everyone
I have just aquired a beosound ouverture that I am currently restoring, I have noticed a unusual "quirk" the cd player it plays well enough with play,  track fwd skip, repeat, random, etc all working  as they should. The Quirky aspect is that the CD Lens will often park midpoint up the length of the travel its the small clamper version and is a CDM 12, if when i remove the disc and press CD it will park in the normal point "fully to the hub. Any help please.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
MediaBobNY replied on Thu, Mar 14 2013 11:44 PM
Same thing happens with mine.   But I don't find it quirky.  The lens parks where it was reading the CD when you removed it.  When you press CD without a disc inserted it will look for one, and probably has to move to the hub to do this.
Maurice
Posts 108
Maurice replied on Sun, Mar 17 2013 7:28 PM
Hi
thanks for your reply, at least i'm not alone thenwith this "feature" I will probably live with it then.
Regards Maurice
Page 1 of 1 (3 items) | RSS
