I have a question regarding the mk1 or "AV" version of the beo4. How do you selct the command "A.AUX" in the list? Unlike the newer versions there only seem to be choices based on particular B&O TV's and audio systems rather than the ability to list individual commands and arrange them in a particular order.
You should be able to add A.AUX to the extra functions available through the LIST button - see the Beo4AV manual on line through this site, page 10.
Here is a link: http://www.beoworld.org/download.asp?file=Beo4AV_user-eng.pdf
Thank you Guy. I was stuck at "config" and did not press list to take me to add and remove. I am more familiar with the newer versions.
Regards David
