Hi guys
i only use the 8000's for music so I have ruled out the beolab 2. I have also ruled out the 11 because reviews have generally concluded that it isn't quite punchy enough. Would it be cheeky to ask what alternative sub would be well suited to use with the 8000's? Has anybody had any experience with using non B&O subs?
Thanks in advance
Have you checked out a 2? I use one with my 8000s primarily with music and I think the combination sounds great. They get criticised for being slow and boomy, but I think this can be tailored with the right setting and position in the room.
Otherwise I think the B&W PV1 would be an excellent choice, if not quite as easily integrable, especially if you're using a B&O source.
Jonathan
