Question for the BS5 owners with the ripper installed.
Has there lately been issues with Gracenote for metadata when ripping cd’s?
A friend of mine tells me, that he can rip the cd’s, but he is not able to ‘find’ the files afterwards (which will be the case if there are no metadata from Gracenote embedded).
it can be a correlation with the BS Moment issue with Gracenote which results in not having the track moods, nor the artist images fetched anymore.
Thanks, that was my suspicion, too.
But I’d like to have a confirmation, if it is so.
Millemissen: Thanks, that was my suspicion, too. But I’d like to have a confirmation, if it is so. MM
There was a thread some time ago about cd-ripper+beosound5+gracenote=dead.
I cannot find it, but I think the service has been shut down for beosound5
/Jacob
Maybe this one then: https://archivedforum2.beoworld.org/forums/p/29286/234869.aspx#234869
mbolo01: Maybe this one then: https://archivedforum2.beoworld.org/forums/p/29286/234869.aspx#234869
Weebyx: Millemissen: Thanks, that was my suspicion, too. But I’d like to have a confirmation, if it is so. MM There was a thread some time ago about cd-ripper+beosound5+gracenote=dead. I cannot find it, but I think the service has been shut down for beosound5 /Jacob
Wow - you guys are good 👍
I meant that too, but could not find it.
THANKS A LOT.
You are welcome MM
What scares me now is to receive the same kind of answer from B&O for the Moment/Gracenote issue ....
