Playmaker Only Plays At Full Volume...
Beocat47
Posts 116
Beocat47 Posted: Wed, Jul 8 2015 6:06 PM
Hi All,
I've just received a Playmaker bought on eBay, apparently in perfect condition/boxed etc. Connected it to Beolab 6000s with brand new RJ45/Powerlink cables and streamed itunes via iPhone5;  Volume is only at a deafening 'Max' and running my finger around the Playmaker volume control does nothing - the mute function does thankfully work however!
Before I conclude the Playmaker is a 'dud' and start going back to the original owner, is there anything obvious I've not considered checking?
Any ideas gratefully accepted...
liberal
Posts 43
liberal replied on Wed, Jul 8 2015 6:31 PM
Hi Beocat47,
Yes there is an option to have the Playmaker set at full output, there is a detailed manual here, and page 11 gives information about this setting:
http://www.luxussound.com/images/Bedienungsanleitungen/Installationshinweise_Playmaker_EN(1).pdf
I hope that is of some help
Paul
Beocat47
Posts 116
Thanks Liberal,
I have set the Max Volume to 55 via A.Setup - 5 as per page 11, but the speakers are now distorting from the previous full volume experience (and probably damaged...), so I can't have sound on for more than a few seconds as it's still pretty loud! Also, using the A.Opt function on a Beo4 , I've set the IR function to 5  so it should respond to Beo4 volume.
However, turning the volume down with the Beo4, the Playmaker lights up in the centre as if receiving a signal, but the volume doesn't go down.  On my iphone I have sound at '1' as I'm playing the music, but the volume is still full; also the Playmaker's own wheel has no effect either- nothing will turn the volume down.
Note that the Powerlink cables are plugged into Powerlink '1' on the 6000's, and the switches set to R & L respectively, so I don't think it's a 'Line' issue.
Any other ideas are very welcome...
Millemissen
Flensborg, Denmark
Posts 14,680
Are you absolutely sure, that you have stored the new setting?
Did the led turn on green as a confirmation?
Beocat47
Posts 116
Millemissen,
If I knew you better I would kiss you right now..!
I've just gone back and re-input the Beo4 codes as I (thought) I had before, making sure this time that I confirmed everything with a 'GO' - and voila, my Playmaker finally works as intended.
I've noted that you've often solved other's problems on this forum by encouraging them to double-check their code sequences, so I'm very glad that you took the trouble to contribute here; after five hours I was nearly at my wit's end, so thank you once again.
Jonathan
Millemissen
Flensborg, Denmark
Posts 14,680
Beocat47:
Millemissen,
Jonathan
Hi Jonathan,
glad to have helped.
By the way - if I knew you better, I'd let you kiss me ;-))
Aussie Michael
Melbourne, AU
Posts 3,730
Kisses aside, I didn't know that those solutions were possible with the volume settings, not that i have ever had an issue with my PM.
It seems that from the literature that its only available where the PM is connected to an AM?
I also wonder if you could use your BeoRemote One with the PM.
Millemissen
Flensborg, Denmark
Posts 14,680
@Michael
The Playmaker, that Jonathan had bought, obvisiously had ben connected to an external amp - or more likely to an A.Tape/A.Mem/A.Aux input of an audiomaster.
This is a possibility, that B&O described right from the beginning - and that is the way, I used mine (and still do).
For this you need these settings.
There are several other setups described - e.g. you can use it with the NL/ML Converter (the A.Aux) in order to have access to it from everywhere in your B&O network.
But they choose to launch it as a standalone device - probably to adress new costumers and to 'make things simple'.
Of course you can use the BeoRemote One with the Playmaker, set up as a standalone device - if that is what you mean.
Page 1 of 1 (8 items) | RSS
