Help !!! Beolab5 not working
This post has 5 Replies | 2 Followers
mrfunny
Posts 27
mrfunny Posted: Fri, Apr 19 2013 4:30 PM
My left speaker did not work when 2 Beolab's speaker connect to beovision 10. When it started, the light became green, then became red again. But the right speaker is no problem. So, what the problem is that and how can i fix that. Pkease, help me
gysse2004
Hellerup
Posts 192
gysse2004 replied on Fri, Apr 19 2013 7:24 PM
Sounds like an option setting on your BL5. On your Beo4 you can set the option- Download the user manual from B&O, will tell you how to do this.
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
mrfunny
Posts 27
mrfunny replied on Sat, Apr 20 2013 4:01 AM
Hi Peter
can you guide me more specifically?
thanks a lot!
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, Apr 20 2013 10:17 AM
First thing I recommend to do is always:
Disconnect all devices from the mains for some minutes, reconnect them with the master (BV10) being the last one.
Wait a minute and start the system.
Some questions:
- are BL5s connected with the original PL cable - special BL- Powerlink cable?
- are they daisychained or bothe connected directly to your BV10?
- did the system work befor, did you change anything?
- in your setup BL5s should be set to L.OPT 0 - LINK OPTION 0. You will find more info in your manual.
- You wrote - "My left speaker did not work when 2 Beolab's speaker connect to beovision 10." Is it different, when you connect just one speaker ??
- What happens if you change the speakers left to right and vice versa?
- Did you try to reset audio settings in your BV10?
- No more ideas for now...:(
btw I don`t think it`s an option setting issue....
Hope this helps
Stefan
gysse2004
Hellerup
Posts 192
gysse2004 replied on Sat, Apr 20 2013 10:22 AM
Have you told your Beovision 10, what speakers are connected in the menu ?
Try to swop the cabels / speaker.
Peter
gysse2004
Hellerup
Posts 192
gysse2004 replied on Sat, Apr 20 2013 10:25 AM
To quick, i agree with Stefan
Peter
Page 1 of 1 (6 items) | RSS
