I own two Beolabs 3500, one is software version 1.2, the other is 2.0.
I now want to upgrade both to the latest software, but my dealer asks for the serial numbers of them before ordering the upgrade parts.
I don't want to take them both of the walls, because it was hard enough to install them there.
Do the serial numbers really matter ?
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Martin,
You can find details about the upgrade HERE
Given that both your Beolab 3500's are below version 2.1 means I am not really sure why the dealer needs the serial numbers because they are clearly Mark 1 versions meaning they do not have Powerlink for Beolink Wireless and you will be upgrading them to version 2.1 I am guessing.
The serial number is not stored in the unit itself
Regards Keith....
Hi Keith,
I've seen your faq. I don't know why my dealer asked for the serial numbers. I told him that I want to upgrade to sw 2.1 but he suggested to upgrade to 3.33. Is it possible to upgrade to 3.33 even if my 3500 are both MK1 ?
BeoIce:Is it possible to upgrade to 3.33 even if my 3500 are both MK1 ?
Martin, That is a very good question
Without question you can upgrade both Mark 1 & 2 (not that you should ever find a Mark 2 at that level) to software version 2.1 BUT if a Wireless 1 is connected, the connection can ONLY be made via the MasterLink.
Version 2.1 replaces the micro-processor PCB36 Part Number 8006009
Software Version 2.1 basically changes the display as below:-
I can see no reason why you cannot upgrade to the latest software version 3.33 which also requires micro-processor PCB36 with a new part number of 8002944 to be replaced. However, this new software really only provides two extra facilites:-
Taking the above into consideration, I would just upgrade to version 2.1 which certainly does not require the dealer to know serial numbers.
Thanks again Keith,
today my dealer told me that he won't get the required parts from B&O munich anymore because he's no more a certified a/v dealer.
I found another dealer nearby who is certified and he'll order the parts for me.
On the Beolabs 3500 I will go for sw 2.1 as you suggested.
Kind regards
Keith_5F00_Saunders:Software Version 2.1 basically changes the display as below:-A.TAPE -> A.MEM A.TAPE2 -> N.MUSIC V.TAPE -> V.MEM V.TAPE2 -> DVD2 CDV -> DVD PHONO -> N.RADIO SAT -> DTV
beopaul:Either they have a really really old BL3500 on their wall, or else recent SW can still display old source labels
Your dealer had his Beolab 3500 prior to version 2.1
