Beomedia 1 N.Music direct folder selection with BEO4
This post has 2 Replies | 2 Followers
georgey007
Posts 74
georgey007 Posted: Sun, Apr 14 2013 1:17 PM
Hi
I recently bought a used Beomedia1 and I installed it as a N.Music and N.Radio server.
I copied Music on the Harddrive and I'm in folder view on the Beomedia1.
Now i want to play the music from my Beosound 3200 and I want to select different folders per number, I stored them under Numbers so I now what Folder is what Number.
I tried to Press the numbers on my Beo4 but i can only select the song in the current Folder, Folder change via FF Key on Beo4.
Is there a way to select the folders directly ?
Regards
hfat
Vienna, Austria
Posts 663
hfat replied on Mon, Apr 15 2013 6:58 AM
No, there is no way to select folders by number.
hfat
georgey007
Posts 74
Page 1 of 1 (3 items) | RSS
