Beomaster9300 / Beolink1000
georgek92
Posts 1
georgek92 Posted: Wed, Apr 17 2013 3:46 AM
Gentlemen,
I need your advice. I have the Beocenter 9300, and a remote control Beolink 1000 for some years, working together perfectly. Until one day, when I was trying to reprogram my Light Controller LC2 to be off after a power failure. Not only that I did not manage to change the on state after power failure but most important, since I tried this reprograming of my LC2, the Beocenter stopped responding to the remote (even though it works perfectly with the manual control) and I tested the Beolink, it's OK. Is there something like a Master Reset? What should I do to return it to the remote operation?
Thank you,
George Kren
California
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Apr 17 2013 6:29 AM
Try A.OPT 1 by pressing SOUND  1 STORE.
Did you touch the black dome while programming your LC2 ?
Hope this helps.
Stefan
Page 1 of 1 (2 items) | RSS
