Hi Kai,
Think you will need to connect via a scart lead as well!!!
Jonnie
Maybe there are different Options on how to Transfer the Sound: Dolby digital, Bitstream, PCM etc.
Maybe even Audio Transfer via HDMI has to be activated?
Have you tried this?
Ralf
Maybe the volume is turned right down or has been muted using the Sky Remote - sounds daft but is an easy mistake to make!
EDIT: But probably not the case here as you cannot (usually) control volume of an output source over hdmi!!!
sometimes I find sky box freezes pic ok no sound, unlug sky box from power 10 secs reconnect maybe the problem worth a try
malcolm
