beocom 2
This post has 10 Replies | 0 Followers
Jenette
Posts 8
Jenette Posted: Thu, Apr 18 2013 11:36 AM
Hi can any one help I'm having a little problem with a beocom 2 which cuts out after a couple of minute when on a call  can any one suggest anything to try.
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Apr 18 2013 11:49 AM
Is the battery quite old?  May need replacing.
JC
West Yorkshire
Posts 764
Silver Member
JC replied on Thu, Apr 18 2013 11:52 AM
I'd guess battery Jenette
Jonnie
Jenette
Posts 8
Jenette replied on Thu, Apr 18 2013 12:06 PM
Not sure I bought it and resold it so don't really know but what they are saying is when they use it it cut off after a couple of minutes and makes a buzzing noise, I havn't a clue, can you change the battery.
Jenette
Posts 8
Jenette replied on Thu, Apr 18 2013 12:10 PM
Hi Jonni thank's for your reply I don't know as I bought it and resold it he says it cuts off after one or two minutes and sometimes makes a buzzing sound can you change a battery in these.
JC
West Yorkshire
Posts 764
Silver Member
JC replied on Thu, Apr 18 2013 12:10 PM
It is a job done in most stores at it needs a special tool to remove it. It can be a diy job but you need to be careful.
Jonnie
Jenette
Posts 8
Jenette replied on Thu, Apr 18 2013 12:17 PM
I think I'll give that a miss, I don't mind doing the batteries in a beocom 6000 and beocom 4 but sounds to fiddlely for me, I know my limitations
JC
West Yorkshire
Posts 764
Silver Member
JC replied on Thu, Apr 18 2013 2:28 PM
If I remember it is about £20 to £30 to have one replaced.
Jonnie
Jenette
Posts 8
Jenette replied on Sat, Apr 20 2013 9:38 AM
Morning Jonnie,  I'll check with b&o this morning
Jenette
Jenette
Posts 8
Jenette replied on Sat, Apr 20 2013 9:55 AM
I so much for your £20-30  just been on to b&o £100minium!!!!!!!!!!!!!!!!!!!!!          I thought so b&o don't do anything cheap
JC
West Yorkshire
Posts 764
Silver Member
JC replied on Sat, Apr 20 2013 9:59 AM
Sent you an email Jenette!!
Page 1 of 1 (11 items) | RSS
