Hi all,
Have not posted for a while but am stuck with the above question. Is it possible for me to connect a laptop (for playing films) to the Aux Camcorder jacks on the left hand side of a BV5? I have previously connected a camcorder and that is all fine, but what hardware/software do I need to get the laptop screen up on the BV5 if at all possible? or is there another route I should follow in order to connect the PC?
Many thanks all,
Thank you for the response. Just bought a converter and will see if it works :)
