BM5/BS5 Cloning from a 500mb harddrive to a larger harddrive
This post has 0 Replies | 0 Followers
Fritz
Posts 272
Fritz Posted: Sun, May 19 2013 2:13 PM
Any one that has a solution by cloning from a 500 mb harddrive to a bigger IE from 500 MB to a 2 TB
It goes fine making the four partitions and BM-System points on (Data) E:BM-Share/system. The size of Recovery, System and BM-System is the same. Only Data has been larger. All data has been transferred.
All partitions are laying in the same order as on the old 500 mb harddrive.
All working fine when BM5 is working as a standalone. When BS5 is connected NetMusic and NetRadio works as intended without any problems.
The problem arises when going into SETUP mode in BS5. After about 3 seconds the system restarts/reboots. Before this the correct available disk storage is shown on the DATA drive and the pointer can be moved. The only item that is not working correct is SETUP. By using the television both serials are displayed and here all is working as intended.
All files in BM-System are present and there is access via the shortcut in BM-share folder, and via BeoPort/Beoplayer
Recovery does not solve the problems
brgds /fritz
Page 1 of 1 (1 items) | RSS
