Hi
My BV10-46 ist responding to IR comandes if i have the ML cabel connected all other BV in my house are working fine and sending comandes to my BS 9000.
I tried to change Cable and Unplugged everything!
If the ML cabel on my BV is connected even the TV command isn't working, I can only switch the TV on if the cable is disconnected!
Please help!!
regards
