Just returned home from a weeks holiday, to now find the front (flip) panel on the Beomaster 5000 won't close. I'd unplugged everything before leaving, and plugged everything back in before operating. I pressed the open button on the panel and it flipped down, when I try to close it, it won't shut. The heating was turned off during the break and is now back on, the room is still chilly.
any ideas?
Tony
After I left it a while and the room had warmed up, it started working
