Apple TV on Beovision 11 - Control
This post has 8 Replies | 2 Followers
Hermann_
Posts 52
Hermann_ Posted: Sat, May 18 2013 10:13 AM
Hi together
At my Beovision I have an Apple TV 2. gen.
I have the IR Eye on PUC1 and have made the setup. With witch button on Beo4 (new one) can I control Apple TV?
Thanks in advance for your help, Hermann
elephant
AU
Posts 8,219
elephant replied on Sat, May 18 2013 10:15 AM
That depends on what source you associated with the AV port that the Apple TV is connected to.
Since I use my ATV more than my DVD, I assigned DVD to be the ATV, and DVD-2 to be the DVD.
BeoNut since '75
Hermann_
Posts 52
Hermann_ replied on Sat, May 18 2013 10:17 AM
I have Apple TV also at the button DVD and can start it successfully. But how can I the control the Apple TV with Beo4?
elephant
AU
Posts 8,219
elephant replied on Sat, May 18 2013 10:21 AM
Hermann_:
Sorry for not understanding.
[<] and [>] allow you to scroll left and right through various menus
[ v ] and [ ^ ] allow you scroll up and down
(GO) allows you to select
[EXIT] allows you to go up one menu level
you can use the Apple remote if you can't get everything to work OOTB
do you have a Beo4 with ajoystick rather than a (GO) button ?
BeoNut since '75
Hermann_
Posts 52
Hermann_ replied on Sat, May 18 2013 10:28 AM
Thanks a lot for explanation. Unfortunately nothing does work by my installation. I have no idea, what I make wrong. Does maybe anybody has an idea?
elephant
AU
Posts 8,219
elephant replied on Sat, May 18 2013 10:39 AM
If the Apple supplied remote works and the Beo4 does not, then you have a problem with the PUC connection.
Have you wired the PUC cable to the front of the Apple TV and sticky taped the repeater eye over the top of the ATV's eye ?
(I don't have a BV11, but that's the way I did it, I presume the BV11 does not have a special connection for the ATV .....)
I have a vague recollection that as part of the ATV setup you have to activate the remote control ... did you do that ?
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Sat, May 18 2013 10:42 AM
elephant:
see page 21 -- http://manuals.info.apple.com/en_US/Apple_TV_2nd_gen_Setup_Guide.pdf
I don't think you have to do this Smile
BeoNut since '75
Hermann_
Posts 52
Hermann_ replied on Sat, May 18 2013 10:51 AM
You are great, thank you very much.
The problem was the ir eye, it hadn't have free view to the Apple TV.
elephant
AU
Posts 8,219
elephant replied on Sat, May 18 2013 10:56 AM
Hermann_:
My pleasure - enjoy !
Left HugGiftRight Hug
BeoNut since '75
Page 1 of 1 (9 items) | RSS
