Please anyone, go your "My Files" add a new folder and try to open it, to upload a file to it.
I did this a couple of times and I can add folders but trying to open them I get the 404 message.
I want to know if I have problems on my side, or its general for the forum.
Worked fine for me.
Søren Mexico: Please anyone, go your "My Files" add a new folder and try to open it, to upload a file to it. I did this a couple of times and I can add folders but trying to open them I get the 404 message. I want to know if I have problems on my side, or its general for the forum.
I think this issue is now fixed, please do some further tests..
Regards Keith....
I'm on it now, but still some problems, will be back with it in a minut
I could make 2 folders, they opened OK, could upload files, but trying to make a folder in a sub folder, again the 404, from parent folder I tried again but same result, 404 again. But it did work with 2 folders at first.
