Greetings, Does anyone know how to access and print an album list from a BeoMaster 5 in a Mac computer?
Do you have it synced with your iTunes Library? If so, then you can print from iTunes!
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Hi Michael,
Thanks for the reply, yes part of the BeoMaster's library is synced to iTunes but I also have ripped hundreds of CDs.
if you use a PC just use MP3tag by choosing Export in the File menu.
Choose the main directory with all subdirectories and music files. Be sure that MP3tag reads the active directory and it's subdirectories (an option)
Carolpa: if you use a PC just use MP3tag by choosing Export in the File menu. Choose the main directory with all subdirectories and music files. Be sure that MP3tag reads the active directory and it's subdirectories (an option)
Or he could import the ripped CDs into iTunes ... choosing the option to not copy the files into iTunes, just the meta-data that can be matched to iTunes for art work etc
BeoNut since '75
