Hi Guys
Need some help please with a Beovision 32" MK3 which I have just bought.
1st I wanted to update the DVB software but cannot find the USB socket (I can't find the socket as described in the user manual (ie under the push flap next to the satellite card)
I also cannot switch off subtitles on some channels, even if you go to DTV setup, then subtitles and switch to no subtitles the titles go off but when you come back to this particular channel they reappear.
I'm sure this is just user error but any assistance would be greatly appreciated.
Many thanks
Mark will call tomorrow, latest sw update means that you have to turn subtitles off in two locations....
