Have been working with my Beomaster 900 tonight.Its been a bit confusing as I downloaded one service manual here , and have two other myself.Guessing different type models over the years.After reading on the archived forum , I realized that I most likely is missing the stereo decoder as most Beomaster 900 do.
Verify me or correct me if I am wrong....... It=s here in the empty slot to the right it should been?
My re-capped M75 are my precious diamonds.
Christian Christensen:Verify me or correct me if I am wrong....... It here in the empty slot to the right it should been?
Yes. Somewhere below the visible image you will find the connector it plugs into; it should now have a dummy plug inserted that contains a couple of components for FM de-emphasis.
--mika
Kiitos, thanks, Mika
