Would anyone know what software version would be in a wireless manufactured in 2011? I'm looking at a used one and am curious if I need to budget a software upgrade into purchase.
Thanks,
Stan
Stan,
There has been very few software updates to the Beolink Wireless since its introduction and since 2011 I believe there has only been one update which solved the following issues:-
The current software version is 2.10e which was introduced in April 2011
The previous software update was in 2007
Regards Keith....
It is also important to know that if you already have BeoLink Wireless you need to make sure all are on the same software version or they do not install/work with with each other.
Stoobie
