Hi!
Anyone controlling a XBOX 360 with a Lintronic? I use it to watch DVD (and my children use it as a XBOX).
I find the commands in the Lintronic list, but nothing happens when I try them. Do the XBOX 360 use IR?
Hi Daniel,
There are different versions of the Xbox using different IR Codes. I use the 1039 codeset. It's in the Lintronic database. IT's worth a try.
hfat
