Beo6 and IP command
This post has 5 Replies | 2 Followers
coolpix
Posts 18
coolpix Posted: Tue, Mar 19 2013 10:24 AM
Hello, is it possible to control various devices to  Ip protocol with my beo6 ?
thx
frank2u
Posts 80
frank2u replied on Tue, Mar 19 2013 1:04 PM
Sorry, I have no answer but this would be a reason for an update from my Beo5 Smile
Frank
mjmedlo
Posts 922
mjmedlo replied on Wed, Mar 20 2013 2:57 PM
you could always add a master link gateway.
it allows things to be connected to it and controlled via Beo6
DocLeisure
Posts 101
Hello,
I have a Masterlink Gateway and I am looking exactly for that Feature.
Is it possible to control an external device via IP Command (HTML-String) with a Masterlink Gateway. Unfortunately I was not able to locate this function.
Any ideas?
Any help is highly appreciated.
Best regards
mjmedlo
Posts 922
mjmedlo replied on Sat, Jun 1 2013 7:27 PM
I'm unsure exactly what you mean.
Can you spell out what you want to accomplish?
DocLeisure:
Hello,
Any ideas?
Best regards
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Jun 2 2013 8:23 AM
I don`t know if this is what you think about:
You can use "custom strings" to be controled by the MLGW. I`m using this function to control my Lintronic relay board via RS 232.
Now it`s possible to control the blinds via IR (Beo4,6) , Beolink app, home automation app (iphone, ipad) and programmed switches.
This works great. You can download the MLGW "help" manual from: mlgw.bang-olufsen.dk
Or maybe the Lintronic box is able to use IP commands...(?) www.lintronic.dk
Maybe this helps...
Stefan
Page 1 of 1 (6 items) | RSS
