I just got a Beomaster 4000 tuner-amplifier and the speaker clips are quite unusual to me. I have never seen such a clip design on the back of the unit. How do I find the proper speaker clips?
I don't understand. You mean the DIN speaker outlets?
They are very common, not to say ubiquitous in Europe!
http://en.wikipedia.org/wiki/DIN_connector
Where do you live?
Jacques
Welcome to Beoworld !
Those plugs/connectors are not as unusual as you may think.
The 2-pin speaker DIN connectors are the only speaker plug/socket standard (industrial norm) for home HiFi worldwideso, naturally, B&O uses these.I am amazed how many people find these plugs strange and/or think they are "proprietary" when, in fact, it'severything else that's non-standard.
The plugs come in several different qualities, both for screw-mount and for soldering.I personally like the Deltron metal type (but it requires soldering).
An Ebay search brings up many:
http://www.ebay.co.uk/sch/i.html?_odkw=din+speaker&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR1.TRC0.A0.Xdin+speaker+plug&_nkw=din+speaker+plug&_sacat=0
I too use the British-made Deltron DIN plugs. Very sturdy and not expensive!
If you live in The States - and I suspect you do - go to Ebay and buy something from user "lazerwave," such as this.
