beovision 4 dark screen issue
This post has 1 Reply | 0 Followers
andreabang
Posts 4
andreabang Posted: Mon, Apr 2 2012 7:57 PM
So please,can anybody tell me, if the old beovision 4(the one with the bezel front) has the light sensor situated in the infrared "eye". I mean that object separated from the tv, that receive the remote control signals.And in Yes, is there a way to disable it???
Best regards!!
root
Posts 226
root replied on Mon, Apr 2 2012 11:40 PM
Depends on the model and sw version. Later models came with the auto contrast IR eye.
Or look at the IR eye. The basic version has just 3 wires connected, the later one 7 or 8, not sure.
Page 1 of 1 (2 items) | RSS
