Hi I currently have my lamps plugged in walls using x10 plug in modules which I operate with my "Marmitek x10 remote control" does anyone know if I can use my Beo4 to operate my x10 lights eg dim / on/off etc ?I believe there is a product I can get but as of yet slightly unclear if possible ..
JONNIE: does anyone know if I can use my Beo4 to operate my x10 lights eg dim / on/off etc ?I believe there is a product I can get but as of yet slightly unclear if possible ..
Beo4 can not control X10 devices, however you can buy a box that translates the signal from B&O codes to X10 protocol. I found this, but it is an old link. I am sure you will find a solution if you google Beo4 x10, that you can buy where you live or on the internet.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I looked into X10 and B&O as I had a load of X10 and used it with my Phillips Pronto but wanted to use my Beo4. I moved on to Homeeasy and Lightmanager-B&O and it works a treat with both my Beo4 and Beo5 and very reliable.
However, you want to know about Beo4 & X10, I very nearly bought the item Michael suggested and saved a link to it ages ago. I just went to it and it and it seems to be still available here.
Lintronic might also be something to consider as that seems to do X10
Stoobie
Cheers guys, yes I saw the "Marmitek b amd o box enquied about it and no one got back to me and now not on sale ? have had a look at those websites great info thanks ! Still all looks quite complicated really just wanted a rather inexpensive way to see if I could control my x10s with my beo4 !
Thanks for info
