Beolit 12 is a fail
This post has 25 Replies | 1 Follower
Milos
Belgrade
Posts 37
Milos Posted: Fri, Jul 5 2013 11:20 AM
Yes it is. They have told all the dealers that they should replace them right away if someone report any kind of problem, specialy with batteries. This is third one I got from local dealer and it turn it self off completely when working on battery. Some of them after few hours but first one I had started that issue after two months! There is also two types of them on the market. First series had on the inside of the back door manual with lot of iphone setting pictures. That one is rly good. But the second one and the curent you will recognize with only four pictures on inner side of doors. Also no little hole for cable. It's bit lighter, cheeper plastic and sound is so plastic like theres no LBA at all. Simply not Bang.
I know there is ppl with working beolits but generaly its cheep problem. No time for extreme testings like before? In China? This problem is widely reported in four countryes atm. God damn it.
bayerische
Ekenäs, Finland
Posts 4,770
So the "mk2" would be more cheaply made then?
Too long to list....
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk replied on Fri, Jul 5 2013 2:44 PM
bayerische:
Looks like it!
It does appear that they launch a product, then find a cheaper way to produce it at a later date. I noticed that on the Beolab 4000 & even as far back as the C75 speaker which became a cheaper to produce CX100.
If you think nobody cares, try missing a couple of payments.
bayerische
Ekenäs, Finland
Posts 4,770
Stonk:
bayerische:
Looks like it!
True, the BL5's where changed too. New models have the thin not grounded power cord, old ones as mine have the "proper" computer-like power cord.
Flappo
Posts 850
Flappo replied on Fri, Jul 5 2013 3:08 PM
i don't see the pint of the beolit 12 personally
doesn't the iphone have a radio built in already ?
Milos
Belgrade
Posts 37
Milos replied on Fri, Jul 5 2013 3:28 PM
And I really doubt its solid aluminium on mk2 since its not "cold" in hands, rly wierd like some plastic grill.
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jul 5 2013 4:19 PM
No problem at all, because Beolit 12 Mk2 costs only 100 €!😜
bayerische
Ekenäs, Finland
Posts 4,770
Raeuber:
I fail to follow. Huh?
Flappo
Posts 850
Flappo replied on Fri, Jul 5 2013 4:53 PM
we have our istuff
we should pity them tbh :)
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
After reading and then rereading the OP several times, especially the "replace them right away" part ... sounds frankly as though counterfeits have wiggled into the supply chain and this is all a big hush-hush!!!
  • One B&o bottle opener
  • One fancy gun
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Jul 5 2013 8:38 PM
ɓʋɾɑɳɫɘɮ:
An interesting thought, one certainly sees a ton of counterfeit A8 headphones on eBay and such. Perhaps one disadvantage of producing things in China is that someone inside will leak the major design drawings and such to counterfeiters. I've seen instances where the firms making DVDs of movies have had such intellectual property pilfering.
I guess it's one of the many things you have to consider with any production location decision...
Jeff
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Jeff:
Apparently Form 2's now as well.
elephant
AU
Posts 8,219
Stonk:
bayerische:
Looks like it!
certainly is a tried & true (and accepted) practice of Apple ... iPhone 3 -> 3GS, 4 -> 3S, 5-> ? + ??
but the Apple quality does not decline - just more internal efficiencies (or so it seems)
However I can't believe that B&O would be silly to compromise the external finnish which is such a strong part of the brand
I "like" Sad the theory of lookalikes slipping into the supply chain ... makes one hopping mad to think of the additional expense B&O may now have - at a time when they can ill afford that !
BeoNut since '75
bayerische
Ekenäs, Finland
Posts 4,770
Elephant, I agree with you on the Apple thing, however...
You took the iPhone as an example, yes the iPhone1 was a marvelous device, and so beautiful, the 2 and 3's where horrible. But from iPhone 4 the quality of the design and materials used once again got better. I like the 5'er, but it does scratch very easily. On the other hand it's great to have the antennae problems gone, and no back-glass, which was just another piece of glass that needed replacement if you dropped it. Yes - thumbs up
Gatex
Posts 129
Gatex replied on Sat, Jul 6 2013 8:40 AM
beoshit 12 is shitty, MK2 its like buying a hoax product from the dealer. I will get the Loewe 2 go protable speakers. if i can sell the beolit but nobody wants to buy it from ebay.it sucks
bayerische
Ekenäs, Finland
Posts 4,770
Seriously, it's this bad?
Is the mk2 currently at dealers shelves? I haven't played with the product since in Struer last year, at the B&O headquarter store, it felt nice and massive then.
Jens
Frankfurt
Posts 17
Jens replied on Sat, Jul 6 2013 11:29 AM
I personally like my Lit12,though I also had my first one replaced due to the battery not charching anymore.I admit that the wireless connection is some sort of a weak spot though...otherwise its a fine  product with superb sound IMHO
Regards
Jens
Beovision 10-40(withA-TV and Wii) with Beolab 6000, Beolab 11 and 2 Beolab 14,Beo4,Beosound 8,Beolit 12,Beoplay V1 32,Beocom 5,Earset 3i,Beoplay H6
scottyltd
Posts 19
Oh dear Flappo. After the amount of times you have posted I would have though you knew about this product.
BeoLit is a portable speaker with no other function (No radio music etc..). The cool thing is that you can stream music to BeoLit 12 wirelessly from the iPhone and enjoy 120W+ of amplification. The speaker really is a powerfull speaker built into a very small box. It looks cool, it feels cool, and yes, you look cool with one of them.
Come on, buy a BeoLit 12 and share your music with your friends. You won't regret it!
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Jul 6 2013 2:19 PM
Just put an Apply logo on a concrete block, he'll buy it and never complain that it doesn't work. Stick out tongue
Jeff
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Jul 6 2013 10:03 PM
Is somebody suggesting an official cost-reduced rework of the Beolit or counterfeits getting into the system? There are reconditioned ones being offered on the online store. Obviously reworked returned units.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
w5bno123
London
Posts 578
There is no such thing as a MKII Beolit12. The first versions had to be setup with an Ethernet cable and due to a sw update thismade it possible to update or connect the Beolit 12 to your router via wifi. Hardly a mk change more like a convenience update?!
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Jul 13 2013 6:50 PM
So this needs rewriting?
http://journal.beoplay.com/index.php/2013/07/attention-to-detail-the-grill-on-beolit-12/
symmes
Posts 247
symmes replied on Sat, Jul 13 2013 7:06 PM
You could post it was made of clay and start a riot.
Flappo
Posts 850
Flappo replied on Sat, Jul 13 2013 8:09 PM
"Just put an Apply logo on a concrete block, he'll buy it and never complain that it doesn't work. Stick out tongue
sounds like you need an integral spell checker
'apply ?'
get a mac
and a life
Puncher
Durham
Posts 11,729
Puncher replied on Sat, Jul 13 2013 9:27 PM
"Apply" is spelled correctly!
Ban boring signatures!
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Jul 13 2013 9:53 PM
No, that's what happens when you use crappy Apple iPad autocorrect when posting instead of using a proper machine, like a PC.
Jeff
Page 1 of 1 (26 items) | RSS
