Good day fellow beoworlders,just came back from a holiday,to be confronted with beolab issues.
The problem is when I switched the input on my lab4000s there is no sound.I have swapped speakers isolated cables etc and both speakers and cables work when set to right,when I switch to left there is no sound.i switched on one speaker independently everything works when switched to right but not left!.the other speakers the same.i have played with balance aswell.when both connected and switched to left and right,the same again,so have concluded its to do with the left switch.can anyone please help me
How are the speakers connected?
Have you tried to tried to turn off tthe 'source' for a couple of minutes?
Could you maybe try another 'source' to see if they behave the same.
Grettings MM
Fixed it new power link cable and it worked unfortunately sound does not sound as clear from left speaker when I adjust balance as it does the right,it sounds quite muffled with not clear treble as the right???
