How can I tell the model year of an MX set?
This post has 5 Replies | 0 Followers
Milton78
Stockholm, Sweden
Posts 39
Milton78 Posted: Fri, Jul 12 2013 8:53 AM
Hi guys,
Is it possible to tell the model year of telly by the sticker on the back, or if not, is there any other way of finding out? What I am looking for, is an MX 7000 pre-Beo 4, i.e. I am looking for one of the models that could utilise the Beolink 5000 functions. Or is it possibly so that B&O upgraded all their sets to only work with one-way communication, once the two-way was kicked out?
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Jul 12 2013 9:10 AM
You can tell the year of production by the Serial number - found here on the Forum:
 1****** - 1984
 2****** - 1985
 3****** - 1986
04****** - 1987
05****** - 1988
06****** - 1989
07****** - 1990
08****** - 1991
09****** - 1992/1993
10****** - 1994/1995
11****** - 1996
12****** - 1997
13****** - 1998/1999
14****** - 2000
15****** - 2001
16****** - 2002
17****** - 2003/2004
18****** - 2005
19****** - 2006
20****** - 2007
21****** - 2008/2009
22****** - 2010
As far as I remember only the MX5500 was two-way (maybe not all models....).
I am sure somebody will know and help out.
Ralf
PS: The Beolink 5000 Looks nice, but imho not as handy as Beolink 1000/Beo 4.
Milton78
Stockholm, Sweden
Posts 39
Milton78 replied on Fri, Jul 12 2013 9:21 AM
Thanks, that is most helpful!
I agree the Beo 4 is the best there is...but since this would be a secondary telly, the Beolink 5000 would be just fine for it, as the current one uses a Beolink 1000 (and I am not a big fan of that model).
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Jul 12 2013 8:16 PM
The year of manufacture doesn't tell everything, as the decisive factor is the software version. I think 2-way was dropped in 2.x, although the hardware was still there; so you will want a set with s/w 1.x (which is shown on the type sticker). These sets will be quite old, so it might not be that easy to find a unit that still has a decent picture.
--mika
Milton78
Stockholm, Sweden
Posts 39
Milton78 replied on Mon, Jul 15 2013 8:34 AM
Hi again,
Thanks, that is also quite helpful. Now off to see if I can find a machine that matches all those requirements (and persuade the people at home that we do need another one...)
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Jul 15 2013 9:47 AM
The safest bet, of course, is to try it with your BL5000 before agreeing to carry the TV set out of the seller's place - I believe most sellers will be quite helpful Big Smile
--mika
Page 1 of 1 (6 items) | RSS
