Beo6 touchscreen problem
This post has 4 Replies | 4 Followers
Griebel
Posts 416
Griebel Posted: Sun, Sep 1 2013 6:28 PM
I got a secondhand Beo6 (from a B&O store!), but there seems to be an issue with the touchscreen.
I have to push very hard to select the functions. Sometimes it doesn't even work (digits for eg), notably the commands near the border.
Is there a possibility to do a hard reset hoping that I can enter that menu?
TWG
Posts 1,672
TWG replied on Tue, Sep 3 2013 11:23 AM
on the Beo 5 you can access a little setup menu by pressing and holding "power off" and the "center/ok" button. But on the Beo 5 was no menu to calibrate the screen
Amazone
Netherlands
Posts 187
Amazone replied on Tue, Sep 3 2013 2:22 PM
Well I don't have to push on the screen of my Beo6 at all, just touch it, like the screen of an iPhone. I'd say just go to the dealer considering you bought it in a B&O store.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Griebel
Posts 416
Griebel replied on Tue, Sep 3 2013 4:06 PM
Yes, I will ultimately bring it back, but I was just wondering if it's possible to do a hard reset to have the default configuration.
Griebel
Posts 416
Griebel replied on Tue, Sep 3 2013 4:08 PM
Right, but once in the menu, can't select anything with accuracy.
Page 1 of 1 (5 items) | RSS
