Beocenter 3500 Questions - UK unit retrofitting for US usage
This post has 0 Replies | 2 Followers
wpmacman
Posts 2
wpmacman Posted: Sat, Jul 27 2013 10:22 PM
I picked up a Beocenter 3500 at a yard sale in North Carolina/USA - just the unit alone with no speakers. The unit is a UK unit so I ordered a simple UK-US plug 'converter'.   When plugging the UK plugs into the back of the converter (and then into the wall),  the red power light comes on. - so I think it's ready to go.   I have a few questions - here they are :
- the back of the unit has a rotary dial with Volts (110, 220, etc).   Do I need to rotate this to 110 or does the convertor handle this conversion ?
- the speaker connectors on the back of the unit are odd looking (I've attached a picture).  They are not  RCA plugs, banana plugs,  or just blacl/red connector points (what I am used to seeing).   Is this a special connection or something that is unique to the UK ?    How do I connect my speaker wire to the back of this unit ?t
- there is a wire sticking out of the back of the unit with an RCA split (female plugs).   Is this there so I can attach am aux unit (i.e., CD player) ?
- The front switches have something called AFC, hi/low filter, loudness - what are these ?
- is there a place to get a turntable belt for this unit ?
- is there somewhere where I can get the users's manual for this unti ?  (I found a service manual but not the user's manual)
Thanks for your help with htis.
Bill
Page 1 of 1 (1 items) | RSS
