Anyone use BV6 as computer monitor
This post has 16 Replies | 1 Follower
bayerische
Ekenäs, Finland
Posts 4,770
bayerische Posted: Fri, Aug 9 2013 12:32 PM
Hi guys,
Any of you use the BV6 26" as your computer monitor? Any big pro's and cons?
Thinking of making it my home computer monitor for use as an external display with my MBP...
The sound will obviously be a big +!
I know the resolution isn't exactly top-notch nowadays.
I got it cheap with the table stand, immaculate condition with not a mark on it, so couldn't refuse.
Too long to list....
Aussie Michael
Melbourne, AU
Posts 3,730
If you have it, I would definitely use it.
I think it looks mickey mouse as a computer monitor.  They use to use them in B&O stores as monitors.
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael
Melbourne, AU
Posts 3,730
Millemissen
Flensborg, Denmark
Posts 14,680
If I had one I would use it as monitor Smile
marcus_m
Posts 517
marcus_m replied on Sat, Aug 10 2013 1:43 PM
I use BV6/22 as computer monitor and already at the size of 22" the resolution is too low for this screen size. Pro: looks and sound :-)
Be also carefull if using Win8, the minimum resolution is 1024x768 - the BV6/22 does only support 720p, so Win8 refuses to work properly :-(
But I think BV6/26 does support 1366x768
bayerische
Ekenäs, Finland
Posts 4,770
It will be used with OSX.
Frederic
Belgium
Posts 121
Frederic replied on Sat, Aug 10 2013 3:00 PM
I do, on a Mac Mini.
Seemed like a good idea at the time, would i do it again seeing the hi-res quality of mac screens: no.
Also picture quality of th BV6 is that good (sometimes dark) and in one of the settings (which I use now) I have two green lines on both sides. Sound of course an the av function (connected to the BS5) are superb.
But in my office I have my vintage BS7000 (depending connected alternately to either BL 9, BL8000 or BL6000) which i use most of the time.
I'll try to post some pictures
Frederic
Belgium
Posts 121
picture 1
Frederic
Belgium
Posts 121
picture 2
Frederic
Belgium
Posts 121
Hidden Colour Laser printer en scanner (PS my BG7000 was at the shop for repair at the time of the picture)
Frederic
Belgium
Posts 121
Cable management
bayerische
Ekenäs, Finland
Posts 4,770
Very cool Fix! Yes - thumbs up
Definitely will use it as my computer monitor then. Will it automatically notice the input, or will the Beo4 have to be used to select the mode?
Rivenflush
Gothenburg
Posts 333
Is the back of the BV6 white from factory or have you painted it?
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Frederic
Belgium
Posts 121
Frederic replied on Sat, Aug 10 2013 7:34 PM
Rivenflush:
Yes it is factory , I thaught and still think it makes the bv much lighter than the black version especially when the back is in the middle of a room
Frederic
Belgium
Posts 121
Frederic replied on Sat, Aug 10 2013 7:40 PM
bayerische:
Thanks,
The mac mini is under V.Mem hdmi1, in the beginning it (through PUC) started and commanded Front Row. But now front row doesn't exist anymore so only starts stops music in itunes. Under DTV hdmi2 I have a setupbox.
I will check the settings of the mac and the bv and try to take a picture of the green lines.
Hereford
Posts 87
Hereford replied on Sat, Aug 10 2013 8:05 PM
Would be neat if B&O applied themselves to make a dedicated computer monitor.
As the market is at the moment, there is basically only Apple making good looking monitors.
Samsung, Dell, and the lot don't even seem to be trying. There must be a decent market of design conscious home offices, high end retail and such that don't necessarily want a grey aluminium Apple screen on display.
Page 1 of 1 (17 items) | RSS
