Can't seem to get sound from either of those two channels. My recent updates have been a lamp kit, but nothing else. Is this an easy fix? The balance channel seems to work fine, when I move it to left/ right one side goes silent.
Welcome to Beoworld !
This is the same issue on basically the same receiver.You will probably be looking at the balance control potentiometer.Yes, one channel goes silent but the other never comes through.http://archivedforum2.beoworld.org/forums/t/7029.aspx
